oil in cooliant but no cooliant in oil?
#21
#22
, I replaced the water pump flushed the radiator took a 60 mile trip to a burger place while in drive thru temperatures got up around 220 hop on the highway drop back down to 190 actually soon as I started moving what's going on I'm at the pressure tested fine I'm going to make sure its cool and see if I see any residue back in the system
#24
Well.nomore getting hot since the drive through? Maybe it was just because it was one of those wrap around drive throughs I had to turn and break alot I figured let me see what's gonna happen f/@ked it's f^&ked so I did about 40 miles@ 90 mph.Radiator cap was cool to the touch when I made it back to the Ponderosa .So I let it idle for 15 Minutes to see if it was the clutch fan and its still cool so I think I'm good after a few more flushes. To get me by to buy a new radiator also after the run&sitting overnite nomore substance on top of coolant. Its just strange it did it that once@the drive through &after I turned the heat on& drove long&hard many many miles she stayed cool&@ idle she stayed cool.Is there a possibility turning the heat on could have burped it?
#25
