Stalling problem 96 1500
Old May 27, 2015 | 03:03 PM
Horde4Life's Avatar
Horde4Life
Default Stalling problem 96 1500
Hey guys, so my truck is acting up, it's a 96 ram 1500 5.9. It seems to be struggling to get gas, it only starts to freak out when I slow down for stop signs and things of that nature, even completely dying sometimes. The rpm gauge just bounces up and down and it struggles for any power. I've replaced the iac and gotten a full tune up including a new air filter but it continues to act up, any ideas what could cause this?
Old May 27, 2015 | 04:07 PM
schmidtp's Avatar
schmidtp
How many miles are on your truck? When was the catalytic converter last replaced?
Old May 27, 2015 | 06:07 PM
Horde4Life's Avatar
Horde4Life
It's got 160,000 on it. I have no idea if the cat has been replaced, it hasn't since I've owned it.
Old May 27, 2015 | 08:11 PM
CPTAFW163's Avatar
CPTAFW163
probably the catalytic converter.
Old May 28, 2015 | 09:39 AM
Moparite's Avatar
Moparite
96's came with bad cats from the factory. (They had a recall) Pull out the front 02 and see if that makes any difference. The cat may be clogged. I'd check the fuel pressure while at it to rule that out.
Old May 29, 2015 | 12:41 PM
Horde4Life's Avatar
Horde4Life
Ok I will try that, is there any way to unclog the cat without replacing it? I don't wanna dump alot of money into this truck. Would a clogged cat make the truck feel starved for fuel? That's how it feels when I drive it.
Old May 30, 2015 | 11:04 AM
Moparite's Avatar
Moparite
yes! A clogged cat stops the engine from breathing.
Old May 30, 2015 | 11:18 AM
Cut the pipe shortly behind the cat, hollow out the cat, then weld the pipe back up.
Old May 30, 2015 | 11:40 AM
Moparite's Avatar
Moparite
May be able to get a new cat from the dealer installed for free (recall).
http://www2.epa.gov/enforcement/daim...ion-settlement
