tranny code
Old Jun 5, 2015 | 06:51 PM
zildjian3707's Avatar
zildjian3707
Default tranny code
was driving and got a CEL. totally lost 1st gear obviously and the code said something about solenoid b shorting. I went ahead reset the ECU. any tips. this is a rebuilt tranny as well but fairly new.
Old Jun 5, 2015 | 09:41 PM
Still under warranty? Take it to where you had it rebuilt.
No shift solenoid for first gear.
Old Jun 5, 2015 | 09:49 PM
zildjian3707
Ya unfortunately no its been a few years. It's gotten the governor pressure solenoid code too in the last month. I replaced that and the transducer last year sigh. Thinking about getting a new solenoid kit and aftermarket gps. I reset my ecu and it's shifting fine again but I don't want it to happen again. Any tips for kits or tips?
Old Jun 6, 2015 | 10:41 AM
Get the BW heavy duty solenoid from Electrical Advantage on Ebay. They sell the sensor/solenoid kit for under 100 bucks.
Old Jun 6, 2015 | 04:16 PM
zildjian3707
http://www.ebay.com/itm/46RE-47RE-Transmission-Solenoid-Upgrade-Kit-HEAVY-DUTY-BORG-trans-dodge-1996-97-/130586256269?hash=item1e678c238d&vxp=mtr ?????
Old Jun 6, 2015 | 04:18 PM
That'll work. Comes with everything you need as well.
Old Jun 6, 2015 | 05:14 PM
zildjian3707
alright. In terms of switching all that out myself, is it difficult? the only thing im not familiar with switching out is the 3-4 accumulator spring included in that kit. where is it at?
Old Jun 6, 2015 | 05:55 PM
Above the accumulator piston. It's obvious once you are inside. Don't even really have to worry about it, if it isn't giving you a problem.
Only fun part is the O/D and TCC solenoids, running the harness without dropping the valve body can be challenging, but, not as challenging as dropping the valve body.
Old Jun 6, 2015 | 06:28 PM
zildjian3707
OK i think i know where that is, is there any behavior that might mean i should just go ahead and switch it out. i thought i was have to drop the valve body to get od solenoid in there but you can do it with it still on?
Old Jun 6, 2015 | 10:31 PM
Supposedly. I think it's just that the harness runs in some awkward places..... check it out when you have the pan off, take it from there. (and let us know. )
