No Start
Old Jun 17, 2015 | 12:30 PM
snowboundrmk's Avatar
snowboundrmk
Angry No Start
So I parked my truck and about 10 seconds later I tried to restart it. I turned the key faster than normal and than what I think is the starter clicked for a millisecond than no lights no nothing. If I unhook the battery I can keep retrying. I hook the battery back up, put the key in it chimes like normal, all dash lights but once I try and engage the starter I just hear (I think) the starter engaging for a millisecond than no lights or anything. Where should I start looking?
Old Jun 17, 2015 | 12:47 PM
Measure the battery voltage for starters. Check the connections.
Old Jun 17, 2015 | 12:53 PM
That's either a dead battery, or a weak connection somewhere. If all power goes away when you turn the key (no lights, no nothin') Start check cables.
Old Jun 17, 2015 | 01:04 PM
CTX's Avatar
CTX
+1 on the battery -- these 2nd gens are so sensitive -- they must have full voltage to work AT ALL
Old Jun 17, 2015 | 03:45 PM
snowboundrmk
All right I'll check it out after work off. Batteries only 2-3 years old, but I'll still check it. Luckily this happened in the driveway haha.
Old Jun 17, 2015 | 07:18 PM
Moparite's Avatar
Moparite
Clean your terminals! These do wonders.
Old Jun 17, 2015 | 07:22 PM
One of my favorite tools.... when I wanted mine, I couldn't find it.... (moving thrice didn't help) so, I went and bought another one.... Now, I think I have four.... as I found them, after I bought one.
Old Jun 17, 2015 | 10:18 PM
snowboundrmk
I checked the battery and it shows 12.5 and when I turn the key to start it just goes to like 12.3 for a split second. And than all the lights go out. Even all the interior lights. Maybe it's the ignition switch?
Old Jun 17, 2015 | 10:23 PM
CTX's Avatar
CTX
How did you check the battery?
"check the battery" by actually using a buddy's battery that has the same or more CCA/CA
Old Jun 17, 2015 | 10:56 PM
snowboundrmk
I just hooked up my multimeter and watched the screen when I turned the key to start.
