4x4 shifter Issues
Old Jul 13, 2015 | 08:24 PM
Eagleye134's Avatar
Eagleye134
Default 4x4 shifter Issues
Alright, I got my truck running perfect again and I thought by fixing the vacuum line issues I had , that the 4x4 would work fine. It drives fine and pulls fine when in 4x4, but my issue is when I go from 2H to 4H , it seems to be hard to find that 4H while the shifter is a lil on the harder side to move to any of the 4H, N or 4L; also if you pull to far without moving the stick to the left, it just goes to Neutral. It only seems to be from 2H to 4H, cause 4L engages and works normally. I dont know much about whats inside of a transfer case that makes them engage, Any Ideas?
Old Jul 14, 2015 | 11:03 AM
Make sure the linkages for the shifter aren't sloppy first.
Old Jul 16, 2015 | 11:37 PM
Eagleye134's Avatar
Eagleye134
All the linkages are good, I even sprayed them with pb blaster lol
Old Jul 17, 2015 | 10:39 AM
Adjusted properly? Nothing bent? Fluid good in t-case?
How many miles on your truck?
