Ac help
Old Jul 19, 2015 | 12:13 PM
drtydn's Avatar
drtydn
Something is awry there then.. Pressure on the low side should go DOWN when the compressor is running. Which port are you plugging in to?
The low side is the only one the canister will fit on. Above the passage side headlight
Old Jul 19, 2015 | 12:15 PM
That is correct.
Low side is suction side. It should not be building pressure. High side is restricted by the orifice tube. It only allows so much to flow. (and expand..... thus, getting REALLY cold) If low side pressure is going up while the compressor is running, I suspect you have some other problem in there as well.
Old Jul 25, 2015 | 09:50 AM
drtydn's Avatar
drtydn
Alright so maybe I was wrong. Today I filled up the wife's car with one of them cans of freon. When I was done I hooked it back up to mine. The pressure builds when the clutch is off but goes gown when it's on. I'll have to get another can and top her off
Old Jul 25, 2015 | 11:49 AM
That's the way it is supposed to work.
