Ignition issues
Ignition issues
It started a while ago but at one time I could pull the key out of the ignition while the truck was running. I could also turn off the truck and start the truck without the key. It only happened a few times. Now I can pull it out while running and turn off the truck but not start it.
Now I can't even start the truck. It turns over but also acts like it's low on battery. Could the ignition be finally going out and causing this?
A little late with the ending to this. So I tested everything I could get off easy. Alt, Batt, etc etc. Started looking into the cables. Found that midway in the positive cable there was a 6 inch spot that was almost completely corroded. So took it off and got a new one off of rock auto. Everything is fine now.
