Ground wire from under hood fuse box
Old Aug 7, 2015 | 11:36 PM
zramsst's Avatar
zramsst
Default Ground wire from under hood fuse box
I putting a hughes fi air gap intake manifold on my truck. Im putting everything back together and i can not figure out where to put a ground wire. Its the big one that comes off the fuse box under the hood. It is bundled together with the ground wire that connects to the power steering bracket. Does anyone know where this wire connects to?
Old Aug 8, 2015 | 09:53 AM
Same place, I think. Does it have the large ring terminal on the end? I know two wires, at least, go to that stud by the pump.
Old Aug 8, 2015 | 03:51 PM
zramsst's Avatar
zramsst
It does have a ring terminal. There are two going to the power steering bracket, one from the battery and another from somewhere on the engine. The one im talking about is a long wire that can reach the alternator but i'm not sure if thats where it goes
Old Aug 8, 2015 | 04:59 PM
zramsst's Avatar
zramsst
Im pretty sure i figured it out. I have it attached to the back of the alternator on the stud with a black plastic shroud around it.
Old Aug 9, 2015 | 11:22 AM
Does it attach to the ground side of the PDC? Or the battery input side?
Old Aug 9, 2015 | 03:00 PM
zramsst's Avatar
zramsst
Ground side i'm pretty sure. Its the black wire in the middle, there is a red wire right beside it towards the front of the vehicle
Old Aug 9, 2015 | 07:50 PM
Can you post a pic?
Old Aug 9, 2015 | 08:20 PM
zramsst's Avatar
zramsst
Its the black wire with a ring terminal that is circled. It'll reach the alternator but i dont know if it connects there
Old Aug 9, 2015 | 10:43 PM
Does that one go down to the starter motor??? I am pretty sure that one is hot as well. Stick a volt meter on it, see what you get.
Old Aug 9, 2015 | 10:54 PM
zramsst's Avatar
zramsst
12.6 volts. I didnt remove it from the starter. I think it goes to the b+ terminal at the back of alternator
