no start in park, only neutral
Old Aug 19, 2015 | 03:55 PM
  #21
LoneWolfArcher's Avatar
LoneWolfArcher
Originally Posted by lisa99
i checked its tight
Oops just saw you replaced the spring. You need Hey You!
Old Aug 19, 2015 | 04:34 PM
  #22
lisa99's Avatar
lisa99
Had a broken spring in 3-4 accumulator, replaced it,truck started in park. this is just a bad dream
Old Aug 19, 2015 | 06:54 PM
  #23
Verify your fluid level. Have to check in in neutral, checking in park will give you an artificially high reading.
If that's ok, (or topping off fluid doesn't help....) verify the external linkage is doing what it should.
Old Aug 20, 2015 | 01:43 PM
  #24
lisa99's Avatar
lisa99
i think the truck beat me. I dropped the pan again, and there was a broken piece of plastic
Old Aug 20, 2015 | 03:17 PM
  #25
Any idea of where it came from? The only plastic I can think of, aside from the accumulator piston, would be the electrical connector.
Old Aug 20, 2015 | 04:16 PM
  #26
lisa99's Avatar
lisa99
no idea. its brownish in color.Dropping the valve body again. Im getting pretty good at it.
Old Aug 21, 2015 | 07:58 PM
  #27
Take a look at the electrical connector (8 pin) first..... might be a chunk of that.
Old Aug 22, 2015 | 10:11 AM
  #28
lisa99's Avatar
lisa99
actually the piece came from the neutral safety switch, but when I dropped the valve body the detent spring and ball fell out. Could that be my problem all along?
Old Aug 22, 2015 | 10:26 AM
  #29
Possibly, if the linkage wasn't staying in the right spot to trigger the switch......
Old Aug 22, 2015 | 11:35 AM
  #30
lisa99's Avatar
lisa99
well the ball bearing decided to make a run for it, guess ill be looking for that
