2000 1500 5.2
Old Aug 12, 2015 | 05:53 PM
Larry Hunter's Avatar
Larry Hunter
Default 2000 1500 5.2
When I first start my truck it's fine but after about 30 seconds it's starts missing real bad and won't go but vibrates like son of a bitch. And it has no power. I just did a tune up, including distributor cap and rotor button. What is wrong with my truck? Please help. Haha
Old Aug 12, 2015 | 06:25 PM
Unplug the front O2 sensor, and see if the problem goes away.
Welcome to DF!
Old Aug 12, 2015 | 08:00 PM
Larry Hunter
It didn't work. Any other option?
Old Aug 13, 2015 | 09:59 AM
Check engine light on? Getting any codes? How many miles on the truck? Any other work been done to it lately?
Old Aug 13, 2015 | 11:56 AM
jrox44's Avatar
jrox44
Firing order wrong? Or rotor or distributor cap on wrong
Old Aug 13, 2015 | 01:55 PM
Larry Hunter
None of that. Firing order is right distributor cap is on correctly. It's got 130,000 miles and nothing has been done but the tune up. Could it be my fuel pump?
Old Aug 13, 2015 | 03:04 PM
Entirely possible, put a fuel pressure gauge on it, and see what it thinks. (you can rent one from any of the big chain parts stores.)
Could also try physically removing the O2 sensor before the cat from the exhaust, and see if that helps at all. (clogged cat?)
Old Aug 13, 2015 | 09:57 PM
Larry Hunter
The fuel pressure gauge said 0 lbs of pressure but it still runs, very ****ty but it's gettin fuel none the less
Old Aug 14, 2015 | 07:32 PM
Is the gauge working? On a 2000 truck, it's wants 49 PSI at idle....... With zero pressure, it shouldn't run at all. Make sure the gauge has the little feller in the fitting that opens the schraeder valve. Also make sure you are screwing it down far enough.
