Question about lift
Old Aug 13, 2015 | 05:57 PM
tianniccari's Avatar
tianniccari
Default Question about lift
I have a 2001 Ram 1500 Sport Off-Road with a 5" RC lift and 3" PA BL. I would like to get my height a little higher. My question is without adjusting anything else (track rod, sway bar links, driveshaft, etc.) could I get away with 2" spacers in the front and a 2" AAL in the back? If so, would you recommend just getting a nice set of 7" could with new shocks or just do the 2" coil spacers? Some time down the line I will upgrade to a new suspension lift so please don't suggest that right away. If I can get away with spending $500 and get the 7" of lift I'll do it instead of a new kit for $2,500-$3,000!
Thanks guys
Old Aug 13, 2015 | 06:10 PM
Well......
Why blow 500 bucks you don't have to, if you are going to replace the lift kit anyway? Do you want to go to larger tires? What size you runnin' now, and what gear ratio in the diffs?
Old Aug 13, 2015 | 06:21 PM
tianniccari
uh oh.. here we go again lol I'm not gonna upgrade any time soon so I'm looking for a long term temporary fix. I'm running 35's atm but would like to go a little bigger. Yet more things to add to the list lol. I wanna do Dana 60s front and back, and upgrade from 4.10 to 4.88. All in time lol this will be sitting in the driveway the majority of the time
Old Aug 13, 2015 | 06:26 PM
Khris1994's Avatar
Khris1994
I could use a nice set of 4.10s for my axles
Old Aug 13, 2015 | 08:11 PM
Stock axles aren't really going to like much bigger tires.... It's a big, heavy truck, and 35's are about the limit for the D44, and 9.25... If you don't drive it much, not as much of an issue, but, something to keep in mind.
You *might* be able to get away with spacers in front, but, I would pay very close attention to suspension geometry. Also, might wanna read the warranty card on your current lift, as I suspect it will be voided should you add spacers..... AAL in the back shouldn't be a problem.
Old Aug 15, 2015 | 01:02 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Thanks guys
Short answers here:
Yes, but don't ever drive it.
No, because you'll not be able to keep it under control based on what you asked.
Old Sep 5, 2018 | 06:18 PM
constable's Avatar
constable
2009 Dodge Ram 1500 4x4
Please include:
Lift Height: 11"
Manufacturer: custom built with Bilstein 5100s on all corners
Tire Size: 38 x 15.50 Toyo open country Mud tires
4x4 or 2x4: 4X4
Comments on the Lift: love it
Old Mar 22, 2019 | 12:51 PM
tomfromdelmonte's Avatar
tomfromdelmonte
Please include:
Lift Height: 11"
4x4 or 2x4: 4X4
Could you share some details on how you custom built your suspension? I'd be very interested, photos etc.
Old Mar 23, 2019 | 11:01 AM
constable's Avatar
constable
I did not build the suspension. A suspension guru did. As far as photos there is not much to show. Most of the suspension is Superlift. Sorry I cant be more help. Iv had this set up since 09 so its been working well
