2001 dodge ram 1500 Transmission issues
Old Sep 8, 2015 | 11:20 AM
jws123's Avatar
jws123
Default 2001 dodge ram 1500 Transmission issues
I have a 2001 dodge ram 1500 slt with 76k miles on it a few months ago i blew a transmission line didn't realize it until the truck stopped moving i replaced the line and now when the truck sits for a while or its really cold out when i first start it up and put it in gear it barely moves if i wait a min or 2 it will move and shift fine should i drop the pan and put a new filter on it? i keep getting mixed answers on dropping the pan and replacing the filter some people say it will make it worse?
Old Sep 8, 2015 | 07:48 PM
zildjian3707's Avatar
zildjian3707
sounds like its not getting enough fluid somewhere fast enough. I'd ask the obvious and wonder if your topped off on fluid.
Old Sep 8, 2015 | 07:51 PM
jws123's Avatar
jws123
Yea fluid is full first thing i checked.
Old Sep 8, 2015 | 10:02 PM
beeker's Avatar
beeker
And you did check in neutral not park correct?
Old Sep 9, 2015 | 09:56 AM
jws123's Avatar
jws123
didn't know it made a difference i will check it again.
Old Sep 9, 2015 | 09:59 AM
Did you eliminate the trans check valve in the line going to the lower radiator fitting? If so, then what you are experiencing is normal.
