NEW 47re wont shift
Old Sep 9, 2015 | 03:36 PM
groenberg's Avatar
groenberg
Default NEW 47re wont shift
So, i got a "new" 47re in my Dodge ram 2500 -97 and it wont shift. I am pretty sure it's an electrical issue since the trans temp and OD off light is on. It can run on 1 gear and reverse. Feels like limp mode.
I have googled alot about this and everyone seem to say that the gov. pressure solenoid needs to be replaced. But since the tranny is new, i think i can rule that out.
I have checked what i believe is the 8 way connector, sprayed it with electrical spray and checked the wiring, and from what i can see, it's all fine.
Read something about the connectors (that 8 way one) can be different, i.e not compatible, but still fits with each other, but i have no idea about that one.
Anyone have any ideas??
Edit: When i first got the tranny in, it shifted fine. Drove just a few km before the transtemp and Od off light came on. I testdrove it yesterday, when i started the truck the light wasn't there, came about 2 minutes into driving. I shut the truck off, and turned the ignition on, and the trans temp light never went out, which it did the first time i started it. I tried the same thing today, turned the ignition on, and no trans temp light was on. Yesterday i put my hand on the pan and i could hold it there easily without getting burnt (when the lights was on)
Old Sep 9, 2015 | 03:42 PM
How do you know it's "new"?
Old Sep 9, 2015 | 03:53 PM
groenberg's Avatar
groenberg
Because the dealer said so? They control check everything so it worked when it left their shop.
Old Sep 9, 2015 | 03:56 PM
Can you take it back? Did you get any kind of warranty?
Old Sep 9, 2015 | 04:00 PM
groenberg's Avatar
groenberg
Yes i can take it back, got 1 year warranty, but i don't think that the fault is in the tranny itself. I can't drive the car anywhere, i'm afraid i'll burn it up or something. I called the dealer today (who bought this tranny from a dealer veeery far away because he couldn't fix my old tranny) and his best advise was "remove the batteries and see if it goes away..... + it took him almost 1 year and a half to fix this, so i'm not so thrilled to send it back.
Old Sep 10, 2015 | 12:11 AM
horatio102's Avatar
horatio102
Oh no!
According to the diag tree, if you have 1st/Reverse only, it's a fault in the governor circuit, a valve body malfunction, or front servo/kickdown band damaged/burned
Old Sep 10, 2015 | 01:06 AM
groenberg's Avatar
groenberg
Originally Posted by horatio102
Oh no!
Governor circuit, i.e. an electrical fault? Any idea what that might include? I will also check the band!
Is there an ODBll connector in the dodge? Have searched but not found.
Old Sep 10, 2015 | 01:18 AM
zildjian3707's Avatar
zildjian3707
yes its directly below the driver side near the accelerator, straight down from the shifter
Old Sep 10, 2015 | 03:10 AM
groenberg's Avatar
groenberg
Great, i'm going to borrow one today and see what codes comes up.
Old Sep 10, 2015 | 07:37 AM
Is the CEL on?
