2000 Ram 5.2 1500 Front Axel Lubrication ?
Old Sep 21, 2015 | 05:23 PM
Supradude's Avatar
Supradude
Default 2000 Ram 5.2 1500 Front Axel Lubrication ?
Hello,
I have a low mileage 2000 Dodge Ram 1500 4X4 Extended Cab. I was told by a friend that I should occasionally put it into 4 wheel drive and drive it to get the lube to places that it will drain off of from sitting for long periods of time. I tried to find an official sight stating these as facts but to no avail. Your input or a link to this data will be greatly appreciated.
Thank You
Supradude
Old Sep 21, 2015 | 05:32 PM
Khris1994's Avatar
Khris1994
It's is a good idea that way the metal parts don't try and seize together but in all purposes I've never seen it written anywhere.
Old Sep 21, 2015 | 07:18 PM
Not going to hurt anything and if it was recommended it would state to do that in the owners manual.
Old Sep 22, 2015 | 12:37 PM
oxymoron29's Avatar
oxymoron29
Spider gears and axles are always turning whether in 2wd or 4wd, so there is always fluid churning. Nothing is going to seize . You could not do it for the life of the vehicle and it wouldn't matter, your choice
Old Sep 22, 2015 | 12:52 PM
Ham Bone's Avatar
Ham Bone
Wouldn't hurt to engage the CAD every once and a while. At the very least you could catch a malfunctioning CAD before you really need the 4x4 to get somewhere.
Old Sep 22, 2015 | 02:56 PM
Khris1994's Avatar
Khris1994
Unless you have locking hubs but yes
Old Sep 23, 2015 | 09:36 AM
None of the second gens came from the factory with locking hubs. That's a custom conversion. (one that I wouldn't mind doing......)
Old Sep 23, 2015 | 09:43 AM
Khris1994's Avatar
Khris1994
If I ever swap to d60s I want to put locking and remove the vacuum switch
