Timing gear set
Old Sep 29, 2015 | 04:50 PM
dodgefan99's Avatar
dodgefan99
Originally Posted by Moparite
I tore apart an LA that had a tensioner, As dodgefan99 said the plastic guide and metal behind it was worn into by the chain. Don't use them.
Yep, I'm worried about more friction once the chain is riding in the groove and also particles getting into the oil.
Old Oct 20, 2015 | 10:56 PM
Brandon Sarver's Avatar
Brandon Sarver
All the fuses are good. I didn't clean the connectors when I hooked new battery up. I changed the key lock cylinder and didn't do anything.that's about all I've done.
Old Oct 20, 2015 | 11:32 PM
dodgefan99's Avatar
dodgefan99
Originally Posted by 1997JollyGreenGiant
I have the Mopar Performance timing set as well. The timing marks on the crank gear are stupid, it has a very large dot on it (which is not the one to use), and a tiny little dot that you can barely even see (use this one). Just be very careful when using this timing set.
Hey, I bought the Comp, I originally commented on this thread about the dots being stupid. The thread was brought back up. Which dot is right then? None of them line up 6 and 12 do they? I was thinking about going Mopar just because Mopar.
Old Oct 23, 2015 | 09:00 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
If you get the Mopar set, there are 2 dots, a big dot and a teeny tiny little dot that looks more like a machining mistake. The teeny tiny dot on the Cam gear is the one to use. It worked for me. I'd stay away from the Mopar set though because of the dot issue.
Old Nov 22, 2015 | 03:13 AM
dodgefan99's Avatar
dodgefan99
Oh my goodness, I've never noticed that little dot. I bought a Comp Cams one and it has way too much slack. I'm gonna make a thread about that little dot, I feel like a lot of people have this problem. I never saw that little dot, IMO it should be on the raised part of the crank gear. Thanks Man!
Old Nov 23, 2015 | 08:06 AM
1997JollyGreenGiant
Sure Thing!
Old Nov 24, 2015 | 03:31 PM
dapepper9's Avatar
dapepper9
I got my Mopar Performance chain with my M1 and I gotta agree the dot issue is dumb. Needs to be more pronounced. However after the big dot wouldn't line up I did some looking I found the little dot. Tried that and it lined up perfect. Double checked the package and it did in fact mention it so I wasn't worried. Also no tensioner.
Old Nov 24, 2015 | 10:43 PM
dbbd1's Avatar
dbbd1
So, messing with valves and pistons and timing usually gives me pause.
I would like to do this and it seems like it is fairly straight-forward. I couldn't find any write-ups on this in the DIY section. How hard is this and any tips/tricks?
(I will keep trying to find a write-up, either here or maybe on another forum)
Old Nov 25, 2015 | 10:55 AM
Timing set is actually pretty easy. Dig down to them, line things up, off with the old, on with the new, and down the road you go. This single change made the biggest difference in how my truck ran. I was amazed at the new-found power the engine had. Of course, with over 160K on the originals, it was REALLY sloppy......
