No 0verdrive on my rebuilt 1998 46RE Transmission
Old Oct 6, 2015 | 08:58 PM
lwiuff's Avatar
lwiuff
Default No 0verdrive on my rebuilt 1998 46RE Transmission
At 155K, it was time for a rebuild on my 1998 46RE transmission. I took it to a reputable shop, and after I drove it for a week, I finally got on the freeway, only to discover that I had no OD. I called the shop, they said come in, so I did.
They called back an hour later and said that I had a Camshaft Position Sensor Circuit malfunction (P0340), and that would prevent the OD from locking up, and that needed to be fixed first.
I'm going to take it back to the shop, but here’s what I have done on my end:
1) Pulled the harness for the Camshaft Position Sensor, cleaned it with contact cleaner, put it back together with silicon grease.
2) Re-routed my spark plug wires as per a TSB notification (To prevent misfires on the No 5 & 8 cylinders).
3) Replaced two - apparently bad - spark plug wires.
I have not thrown any codes that trigger the Check Engine light, but when I connected my ODB, I saw a P0783 code - "3-4 shift malfunction”.
Here are the symptoms:
1) At 60 MPH, I am showing 2,400 on my tachometer, with OD button engaged.
2) When I lift my foot off the gas, RPM drops to 1,250 or so, and bounces between 1,000 and 1,300 if I am on a downhill grade.
3) If I disengage the OD button at 60 MPH -under throttle - engine RPM drops to 2,300 for a moment, then goes back up to 2,400.
4) When I re-engage the OD button - under throttle, at 60 MPH - RPM drops to 2,300, then immediately goes back to 2,400.
5) If I disengage the OD button while coasting, the RPM jumps up to match engine RPM to vehicle speed.
6) If I re-engage the OD button while coasting, as soon as I apply throttle, the transmission “bangs” into gear, while RPM climbs to match vehicle speed.
I have yet to run a second tank of gas through it, so I have no idea what my milage is like at the moment.
I have gone through the Dodge Service Manual troubleshooting section, but I’m not the transmission expert! Any Ideas?
Last edited by lwiuff; Oct 7, 2015 at 02:49 PM. Reason: Camshaft Position Sensor - NOT Crankshaft :)
Old Oct 6, 2015 | 10:49 PM
Think I would have a look at throttle position sensor as well.
Old Oct 7, 2015 | 06:54 AM
Moparite's Avatar
Moparite
The trans shop said you had a cps code but didn't say anything about the P0783? Was the pcm reset?
P0783 3-4 Shift Solenoid, No RPM Drop @ Lockup
I would do a hard dump (pcm reset) and see if any codes come back.
Old Oct 7, 2015 | 02:54 PM
lwiuff's Avatar
lwiuff
No - no PCM reset. I think I threw the P0783 after I picked the truck up... Thanks, guys. I heard back from the shop - they said bring it in.
Old Oct 7, 2015 | 08:59 PM
lwiuff's Avatar
lwiuff
Reset the PCM and went for a drive for an hour or so. Checked for codes - found a P0138. Nothing new - my truck throws that code all the time - even after I replaced the O2 sensor.
Still no OD, so Moparite, I think it's time for a new solenoid
Old Oct 8, 2015 | 12:20 PM
Moparite's Avatar
Moparite
Take it back to the tranny shop and tell them it had the P0783 code and then you reset the pcm. If it worked prior to them rebuilding it it's on them.
Old Oct 8, 2015 | 06:00 PM
lwiuff's Avatar
lwiuff
Shop says it was a bad accumulator. Looking forward to driving it and seeing if it's fixed!
Old Oct 8, 2015 | 09:31 PM
lwiuff's Avatar
lwiuff
Test drive went well - problem solved.It was bad seals and a sticking piston at the 3-4 shift spring.
