Build the 5.9 or swap an LS?
Old Oct 18, 2015 | 03:14 PM
Ham Bone's Avatar
Ham Bone
Stroke it to a 408.
If you don't wanna do a full on engine build just swap the damn LS in it and forget it.
Old Oct 18, 2015 | 03:15 PM
LS swap would require trans, and probably t-case as well. Then you need to worry about driveshaft length, etc.
Old Oct 18, 2015 | 04:00 PM
Spillage's Avatar
Spillage
If he's going from a stock 5.9 to something with 450hp, he really needs to upgrade trans components anyway.
Old Oct 18, 2015 | 04:06 PM
Gaius's Avatar
Gaius
Yeah, not worried about the trans and what it takes to adapt. If I build the 5.9 up, I'd get rid of the 46RE and build an older 727 to get rid of the OD and electronic solenoids anyway.
Stroking it is a good idea.
After running some more numbers, I think I'll have to swap in a 6.0. Keeping this motor doesn;t make sense dollar wise, and if anyone has worked on an LS, they are much easier to work on. The gaskets make it a breeze.
A factory aluminum 6.0 is 345 hp, with tune and some headers I'll be at 400 hp. I can buy a JY 6.0 for less than the price of a set of Eddy Magnum heads.
Old Oct 18, 2015 | 05:19 PM
Ham Bone's Avatar
Ham Bone
I personally Haven't worked on an engine easier than a 5.9 magnum. Buds 78 351M is pretty easy. But there is less room in that truck than you think.
Old Oct 19, 2015 | 10:54 AM
Moparite's Avatar
Moparite
Put a 440 in it!
