Transmission jumping out of gear
Old Oct 26, 2015 | 03:02 PM
PAwrestling#1's Avatar
PAwrestling#1
Default Transmission jumping out of gear
1997 Dodge ram 2500 46RE is what I have and when I bought the truck it had very little stuff to it in Drive. Wouldn't spin tires on gravel. People told me it could be in " Limp Mode " so I checked codes and did have one for governer pressure soleniod so I bought a kit with sensor,soleniod,filter,acc. spring etc. and replaced. Now this truck has play in shifter to where it's hard to find gears but now after repairs it feels to have more stuff but jumps out of drive and reverse. Where do I need to look first?
Old Oct 26, 2015 | 06:14 PM
Check the linkage. There are plastic bushings that wear/break over time.
Old Oct 26, 2015 | 06:38 PM
PAwrestling#1
As in more than one? I looked up on Rock Auto and they list one plastic bushing for shift linkage bushing?
Old Oct 27, 2015 | 11:57 AM
Look at your linkage, take it from there.
Old Nov 14, 2015 | 06:49 AM
PAwrestling#1
Could incorrectly adjusted bands cause this also??
Old Nov 14, 2015 | 10:05 AM
Possibly.
Old Nov 18, 2015 | 12:16 PM
PAwrestling#1
checked linkage everything seems tight and visually bushings seems to be o.k.
Old Nov 18, 2015 | 02:58 PM
Is it properly adjusted?
When it jumps out of gear, can you wiggle the shifter, and have it start moving again?
Old Nov 19, 2015 | 09:47 AM
PAwrestling#1
not sure trying to find info. on that along with band adjusting. I did see somewhere that the band adjustment is a certain spec. unless you use a certain adapter then it's of lesser torque. WHat is this adapter they are talking about
Old Nov 19, 2015 | 10:36 AM
No Idea. Look thru montec's trans corner thread, he has recommendations for band adjustment in there, that are a bit different from the service manual.
