Adjustable control arms
just happen to have a skyjacker DLL-23 lower arm here and in fact they are almost 1/2 inch longer then stock.18 1/2 inches stock...skyjacker almost 19 inches.
Thanks for the pics they look real good. Now let ask by putting those on where will your caster be set at I just put all new steering links on my truck and bout to get it aligned. Post your settings after u have it aligned if it's in spec ill go that route save a bit of cash thanks
Stands2up,
Thanks for the pics. That's the same arms I have although I don't recognize the part number. Maybe it changed. I do recognize the STUPID STICKER that caused serious RUST behind it under the paint. Guess powder coating is just as weak as a rattle can. If those are yours, I would remove the sticker asap.
As for the length, they may be longer. I can't see the other end, haha. Does a half inch make any difference? If I raised the truck with a 5" coil, I'd need these huge long arms that attach way back on the frame. Pretty significant. Maybe that's why all the posts over the years said they were the same length. I installed mine 5 and a half years ago but I remember there being no significant difference.
Big Green,
I'm curious what your caster setting (cam bolts) are currently before you get it aligned. There used to be a post of proper alignment specs floating around the web about ten years ago for Dodges but I have lost it. Mainly it was addressing toe but included caster as well. I put mine just forward of noon and wonder where they should really be. I know that before my lift, when all was stock and perfect, the cam bolts were set differently side to side.
Big Green,
The cam bolts are as far as they can go at 6 o'clock no more adjustment so my thinking and let me know if I'm wrong. By putting longer arms adjustable or not and bring the came back to the least amount of caster then longer arms would have some adjustment left get lol
Stands2up,
Big Green,
Big Green,
