Trying to find out if I can just go with lower arms to have better caster adjustment on the alignment or do I need all 4 arms it's a 3inch lift thanks for the help
Great I was hoping I could where could I find them I've looked but no luck on that type of arm plenty of the ones that u have to take off to adjust to much work
Shouldn't need them on a 3" lift. Mine didn't. I bought the Skyjacker lower arms simply as upgrades. They were the exact length as stock with grease zerks and poly bushings.
The main thing I was going for was adjustability. Trying to do what dodge should have done from the start Thanks for your in put thank a vet today your lifestyle depends
On them thanks for all that gave all and the people that still do!!
