Air in coolent system ?
Old Dec 6, 2015 | 10:54 PM
getdown78's Avatar
getdown78
I did drive it down the road and back after it warmed up just to make sure ! So if it has no air in the system then how do i get hotter heat ?
Old Dec 7, 2015 | 12:14 AM
UnregisteredUser's Avatar
UnregisteredUser
Replace the heater core.
Old Dec 7, 2015 | 12:19 AM
getdown78's Avatar
getdown78
New dash,heater core and the blend door is working right !
Old Dec 7, 2015 | 09:08 AM
Backflush the heater core. Pull both hoses, inlet where there is a coupler on the passenger side head, outlet at the steel tube that goes into the water pump. (put a cork in it to keep the coolant from flowing out. Pinch off the inlet hose, from the intake) Put both hose ends up as high as you can, and run water in the opposite direction of normal flow. When all the air is out, put the hoses back together, keeping as much of the coolant in there as you can.
Should help. Heater core is notorious for having a nice air bubble that is amazingly difficult to get out.
Old Dec 7, 2015 | 09:15 AM
Moparite's Avatar
Moparite
Just a cruise down the road probably wont do it. Take it out and drive it a while(1/2 hour). I have the hole drilled in the t start and will notice it will still pull from the reservoir tank(after i fill if). Needs to cycle(hot/cool) a few times to get all the air out.
