wiring questions
Old Dec 13, 2015 | 12:59 AM
jeepzilla's Avatar
jeepzilla
I *think* oil pressure is the only one that doesn't go thru the PCM. (PCM really doesn't care about oil pressure..... which I find kinda odd.....) Everything else pretty much goes thru the CTM. Do you have a copy of the service manual yet? If not, grab one here.
I do, i have spent the last few days going through the one for the 1978 for the engine and the one for the 1998 for the truck. But i always welcome help when i can get it
Old Dec 13, 2015 | 08:37 AM
Good Plan.
A quick perusal of the 98 service manual, it looks like even the frigging fuel gauge is driven by the PCM........
Old Dec 13, 2015 | 11:49 AM
jeepzilla's Avatar
jeepzilla
It looks to me like there are 2 diferent computers one power control module and one power distribution center.. The distribution controls the instrument cluster... Would it be possible to to keep the instruments? Or more likely it feeds off of inputs from the PCM ?
Old Dec 13, 2015 | 12:52 PM
Moparite's Avatar
Moparite
The pcm feeds the gauges. I'm not sure what voltage they use to drive them but if it's like conventional electric gauges it's 12v. You could calibrate the voltage with the senders and some resistors to get most of them to work. the tach/speedo is a little more of an issue. With some bench testing and enough ingenuity i think it could be done. Mechanical gauges are more accurate and they would look cool in a custom dash. My $.02
Old Dec 13, 2015 | 02:58 PM
Bwally1996's Avatar
Bwally1996
I will be doing a engine swap eventually but I feel Like my truck deserves a 4bt cummins lol
Old Dec 13, 2015 | 05:57 PM
jeepzilla's Avatar
jeepzilla
Thanks.. All $.02 are welcome at this point, i have considered taking the guage cluster apart and fitting in the little 1.5 inch guys in place of the ones that dont work.. I agree it would look very nice
Old Dec 13, 2015 | 09:55 PM
Bwally1996's Avatar
Bwally1996
Time for custom gauges. Lol
Old Dec 14, 2015 | 12:01 AM
jeepzilla's Avatar
jeepzilla
Yes i think so
In the mean time here are some pictures of the engine
Old Dec 14, 2015 | 07:33 AM
The central timer module sends data to the cluster on what basically amounts to a network connection. (CCD bus.....) I have no idea how the data is sent, but, I suspect it works exactly like your computer network, and the data is sent in packets, which the cluster then interprets. I do not think you can synthesize that signal........ Either need to have the PCM hooked up to the sensors it wants, and then feed the cluster, or, switch to custom gauges.
Old Dec 14, 2015 | 09:55 AM
jeepzilla's Avatar
jeepzilla
Yep.. Custom guages time... I suppose i could start a new thread for the build pictures
