fuel injector plug swap!?
Old Dec 13, 2015 | 09:41 AM
1998ram5.9's Avatar
1998ram5.9
Default fuel injector plug swap!?
So right now I'm in the middle of the 318 to 360 swap. Everything has been going smooth until now, the 360 is out of 1999 and my truck is a 2001, and the fuel injector wire plugs are different, but that looks like the only electrical difference. Should I go to the junk yard and get me a whole wiring harness from a 99 or can I just get the 8 plugs I need and splice them in and keep my wiring harness?
Old Dec 13, 2015 | 10:06 AM
Actually, they make adapters to change from the EV-1 (older) to EV-6 (newer) connectors. Check with your local parts stores, should be able to order them up, certainly should be able to find them online.
Old Dec 13, 2015 | 05:56 PM
97ramrod1500's Avatar
97ramrod1500
The adapters would be the easiest, plug and play.
Old Dec 14, 2015 | 12:04 AM
1998ram5.9's Avatar
1998ram5.9
I have ev-1 fuel injectors with ev-6 plugs from the harness. Those I cannot find
Old Dec 14, 2015 | 07:30 AM
Ah.
Summit has 'em. 13 bucks a pop though. Holy smokes. Think it might almost be cheaper to just replace the injectors......
Old Dec 14, 2015 | 07:20 PM
Spillage's Avatar
Spillage
Try these... $24.99 a set of 8.
http://www.route66speedshop.com/fuel-injection.html
Old Dec 14, 2015 | 07:22 PM
Yee Haa. That's MUCH cheaper.
Thanks.
Old Dec 14, 2015 | 08:32 PM
Spillage's Avatar
Spillage
Thanks.
You're welcome... I'm always more than happy to pass on a savings tip that I've picked up in my travels.
Old Dec 17, 2015 | 02:05 PM
tomdoge33's Avatar
tomdoge33
My buddy was doing a lot of work on his truck and needed a bunch of plus/pitgtails for it..
i think he used this place called [URL="http://aeromotive.us"]
