No heat??!!
Old Dec 26, 2015 | 03:31 PM
  #21
Dodgevity's Avatar
Dodgevity
Feel the heater hoses going into the firewall. Are they hot?
Old Jan 5, 2016 | 07:34 PM
  #22
rampulstilskin's Avatar
rampulstilskin
Just replaced the stuck, ironically named "Failsafe" thermostat that I purchased from Autozone for $12 with an $8 195 degree Stat. I only ran the engine for 5 minutes and began to feel heat. Only time will tell how long this one lasts.
Thanks for the suggestions!
Old Jan 6, 2016 | 10:15 AM
  #23
Moparite's Avatar
Moparite
The "failsafe" design is so it doesn't stay closed. It will allow you to drive the vehicle unlike if it was closed.
Old Jan 6, 2016 | 03:03 PM
  #24
Trouble is, they tend to fail just because they feel like it. A standard thermostat is actually more reliable....
Old Jan 6, 2016 | 08:19 PM
  #25
Moparite's Avatar
Moparite
Well that's what stant says anyways. I think it's a load!
Old Jan 7, 2016 | 02:48 AM
  #26
chevelle68's Avatar
chevelle68
I am back to good heat after replacing the water pump. heater core needed flush too. I had experienced weak heat prior to w/p going bad and chalked that up to low water level in radiator and/or an air bubble.
