Transmission fluid? (Lucas)
Old Jan 10, 2016 | 08:18 PM
  #21
dbbd1's Avatar
dbbd1
There is already a magnet in the stock pan. It's a round one, right around the dimple into the pan, drivers back corner of the pan, which, incidentally, is the low point. Just get a great magnet, you don't want it busting loose in the pan and going places that it shouldn't.
That is correct about the add-on drains, they will leave about 1/4". Raise the front end to drain the most out.
Old Jan 10, 2016 | 08:36 PM
  #22
Dodgevity's Avatar
Dodgevity
Originally Posted by bosanci28
Thanks for that info.
Now regarding the magnets , are those any magnets or they must be specially for Ram's trannys? I don't see many on ebay where i look.
I got some strong magnets from Harbor Freight. Just something extra I decided to do. There is already one there as stated.
Old Jan 10, 2016 | 10:22 PM
  #23
Any magnet will do, so long as it is strong enough to hold itself in place over the bumpys.
Old Jan 10, 2016 | 11:53 PM
  #24
2bit's Avatar
2bit
I'd say your due for a band adjustment while the pan is off. There's a DIY or sticky, I think. Which gears are slipping?
