Transmission fluid? (Lucas)
Old Dec 21, 2015 | 08:43 PM
bosanci28's Avatar
bosanci28
Default Transmission fluid? (Lucas)
I am having a little slipping once in a while , not to often but i am thinking about replacing the transmission fluid.
What will be okay from Autozone or Kragen to buy ? I was going to buy lucas oil and the tranny treatment that they have.
Whats your advice?
Truck : 1995 Ram 1500 /cab 2 wheel drive 5.2 (no 4x4) - 255k
I remember that there was a one time fluid replaced in the tranny about 8-9 years ago and we put regular tranny oil plus one of those lucas treatment.
Sec. question:
I remember ,as i have to go and look , is there a tranny pan that you can buy that has the drain plug? as i think the one right now is there to replace the fluid you must take the pan down...
Thanks for any advice.
Old Dec 21, 2015 | 08:44 PM
May help. If you have mechanical issues inside, Lucas won't help.
Old Dec 21, 2015 | 08:50 PM
bosanci28's Avatar
bosanci28
I see, yes it happens no all the time rare.
Auto zone has :
Lucas Oil/Multi-vehicle automatic transmission fluid
not sure if that will be fine.
I guess dodge takes atf+4.
Old Dec 21, 2015 | 08:51 PM
bosanci28's Avatar
bosanci28
How about the pan with a drain ,can those be purchased somewhere?
Old Dec 21, 2015 | 10:25 PM
dbbd1's Avatar
dbbd1
Yes, Dorman makes a stock pan with a drain plug. Those tend to leak at the drain plug though. When the bung is welded in, they don't leave much of a mating surface for the drain plug. If you buy one locally, pull off the drain plug and inspect it before you buy. If you order one from the inter webs, just get an aftermarket one, with more capacity (B&M).
You can also just buy a bung to weld in yourself or a B&M drill-and-nut DIY one.
Old Jan 9, 2016 | 01:51 PM
bosanci28's Avatar
bosanci28
Thank you for that info! Will have to do this soon!.
Regards.
Old Jan 9, 2016 | 02:41 PM
dbbd1's Avatar
dbbd1
I am happy with my B&M one.
Old Jan 9, 2016 | 02:59 PM
bosanci28's Avatar
bosanci28
Do you have a direct link to this one:
"or a B&M drill-and-nut DIY one."
Also i was thinking to get a Bun from here:
http://www.jegs.com/p/ARP/ARP-Weld-B...62716/10002/-1
Thanks,
Old Jan 9, 2016 | 03:09 PM
If you have a good welder, one of the Steel, female, weld-on bungs would work pretty good. Just get a pipe plug to go into it.
Old Jan 9, 2016 | 03:14 PM
bosanci28's Avatar
bosanci28
Yes, I am about to get this welder
http://www.hfcoupons.com/coupon/170-...-cored-welder/
from Harbor Freight , need to build gates for my home and i will do the tranny pan job too.
