So I'm looking at doing pushrods because I've got a couple bent ones and I was going to get valve springs and seals and put them in at the same time. I think I'm going to have to go with CompCams pushrods because they're the only ones I've found. Still looking for springs and seals. I found some Mopar Performance stuff but I have no idea if it fits and the seals say you have to machine the top of the valve guide. Do I have to do this?
Also if you know the size of the valve springs can you tell me. I can't really figure out what springs I need. I want bigger better ones for when I put a different cam in it. Also can you tell me which one of the CompCams pushrods I should go with or if I should go with a different brand. I want to go as much Mopar Performance stuff as possible so if your suggesting different parts if Mopar makes something I'd prefer that. I want beefy parts so if theres a dual versions of the springs I listed that'd be great.
I don't even know if any of these are the right parts so if you could confirm or point me in the right direction that'd be awesome.
Thanks
Mopar Perf Valve Seals
Mopar Perf Valve Springs
Pushrods
Thanks
Pushrods
Quote:
The dealer can on Mopar Performance parts?Originally Posted by HeyYou
Call the dealership, and verify part numbers.
Thanks
Pushrods
You will need different retainers with those springsOriginally Posted by dodgefan99
So I'm looking at doing pushrods because I've got a couple bent ones and I was going to get valve springs and seals and put them in at the same time. I think I'm going to have to go with CompCams pushrods because they're the only ones I've found. Still looking for springs and seals. I found some Mopar Performance stuff but I have no idea if it fits and the seals say you have to machine the top of the valve guide. Do I have to do this?Also if you know the size of the valve springs can you tell me. I can't really figure out what springs I need. I want bigger better ones for when I put a different cam in it. Also can you tell me which one of the CompCams pushrods I should go with or if I should go with a different brand. I want to go as much Mopar Performance stuff as possible so if your suggesting different parts if Mopar makes something I'd prefer that. I want beefy parts so if theres a dual versions of the springs I listed that'd be great.
Thanks
Pushrods
