Truck died three times in 2 minutes
So I was driving my truck home maybe 3/4 mile from my house, slow down to take a turn and the rpms drop all the way down, truck dies
Start it and it cranks for a second and fires up pretty weak but runs maybe a second and dies again
Shut it off let it sit for a minute then restarted it again and gave it a little throttle that kept it running. Took off trying to make it to the house, dropped it into first to keep the rpms up while I turned
Got on a back street closer to my house and put it in neutral and let off the throttle to see if it would die again
It did
Restarted it with some gas drove it home got in the driveway and its idling fine
Tried to kill it by blipping the throttle and it would idle down under 500 but come back up
Couldn't kill it again
So I just turned it off and left it
IAC? Fuel pump?
Checked it for codes as soon as I pulled into the driveway, didn't have any
Truck is a 98 5.2 with 195,000 miles and a bad plenum
It did
IAC? Fuel pump?
