exhaust popping 1996 ram v8
Old Jan 5, 2016 | 04:45 PM
dapepper9's Avatar
dapepper9
If you used platinum plugs or e3 do em again but with copper lol. Otherwise download the factory service manual, it has the procedure in there. Easier than trying to explain it.
Old Jan 5, 2016 | 06:15 PM
j576's Avatar
j576
Um do you have a good source for me to download a manual ? Or should I go on a Google hunt ? Haha and thanks for all the help
Old Jan 5, 2016 | 06:50 PM
Moparite's Avatar
Moparite
What condition is your plenum gasket in? Multiple misfire codes are a tell tail sign.
Old Jan 5, 2016 | 09:19 PM
j576's Avatar
j576
hey so heres a little more info,
1-150psi
2-150psi
3-151psi
4-150psi
5-120psi
6-120psi
7-150psi
8-149psi
P0300 random misfire
P0302 cylinder 2 misfire
P0301cylinder 1 misfire
also threw a PO505 but cleared and never came back !
as for condition of the plenum gasket i am unsure at the moment
Old Jan 5, 2016 | 10:08 PM
What wires did you get? If you just got the 'stock replacement' fellers, check the FAQ section here for the Plug Wire Routing TSB, and run them accordingly. Might be just that simple.
A high of 150, and low of 120.... puts you out of spec. Granted, the individual numbers are good, but, the difference between highest, and lowest, is greater than 10%, which isn't good. I would be tempted to do a cylinder leakdown test, and see what that tells ya.
Old Jan 5, 2016 | 10:15 PM
2bit's Avatar
2bit
A worn out distributor (Bushings) can cause this also.
Old Jan 6, 2016 | 02:11 PM
dapepper9's Avatar
dapepper9
As for the compression, run 2 cans of Mopar Combustion Cleaner through and retest it.
Old Jan 11, 2016 | 05:11 PM
shak's Avatar
shak
Wire Routing very Important!
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Old Jan 14, 2016 | 09:50 PM
j576's Avatar
j576
Default update
So the update is I got my hands on a mt2500 and checked the sync. Its going in between -9 and -11.
Should be set to 0 correct ?
Old Jan 14, 2016 | 10:26 PM
j576's Avatar
j576
And cyl #2 is misfiring like crazy, turned injector 2 off and it ran way better, that mean injector 2 could be bad ?
