I know this is probably a silly question, but I don't work on engines much. Little stumped on how to adjust. from what I gather there's a clamp down bolt that I loosen and have to the turn the whole distributor ?
Could you make my life easy and explain how to do this ? Thanks !
Originally Posted by dapepper9
Set it to +2. 0 is a tad too slow.
Also swap #2 and #1 injectors and see if that follows. If it does you got a bad injector. Not until after seeing fuel sync though
Use the scanner to check how many degrees you're out. loosen the bolt, slowly and very slightly spin the distributor counter clockwise to advance. Tighten bolt and check again.
So I changed the fuel sync to about +2
Saw a small change in how it was running but once it warmed up it started popping again, swapped injectors around and the misfire followed so I got a new injector and so far runs like a champ. Idle is around 1200 which to me seems high ? Maybe that's average for these trucks ?
I'd also like to say thank you to everyone that helped me out ! Couldnt have done it without your guys knowledge ! Much appreciated
I have a popping exhaust, but I don't have any missfire codes, I defiantly have a miss
But I also have a fuel leak
Could the leak be causing my miss. Why isn't there a code for my miss?
