Way to change when TC lockup engages?
Fiddling line pressure (or line pressure signals) probably moved all of your shift points though, didn't it? That part of my brain that thinks it understands things expects that, but the larger part of my brain that knows the world doesn't often make sense is telling me that I should just shut up now...
Disregarding in-town driving where overdrive doesn't happen for me because I've got the habit of poking the button at startup, mine was at 50 MPH indicated (speedo) under light acceleration on the factory unit and stayed at 50 on the Mega Viper. When I threw away the larger tires and went back to stock, it stayed at 50 indicated even though engine load was proportionally lower. What made the big difference for me was the tuner, which when set to go-fast makes the PCM more aggressive in switching that flip. It's now almost perfect for most of my highway driving, but I still switch off manually where it'd otherwise do too much shifting. I'd call it the ultimate reality if the thing could detect injector shutdown and respond by dropping into direct drive and enabling TCC lock, but it's not killing me to manually push the button on downgrades to get that functionality. It's not like anyone ever rolled a really good mountain truck off of an assembly line...
I also push it every time i get in. I don't want it o/d to engage unless I'm on the interstate or highway between all the small towns here. I've noticed significantly lower temps and the trans just acts nicer all around, especially in the summer
Trending Topics
It goes 1-2 2-3 then TC lockup then OD right after
It's annoying because it shifts into OD at a little under 40 mph and it'll be running about 1100 rpms
