Wheel and Tire advise - 16x11 on stock suspension
Old Jan 18, 2016 | 03:50 PM
schmidtp's Avatar
schmidtp
Default Wheel and Tire advise - 16x11 on stock suspension
Hey all,
Need some advise and from what I searched it didn't really answer my question. I found a good deal on some 16x11 Centerline Hellcat rims, not sure of any offset numbers.
Would I be able to use these with a 33"ish tire on stock suspension without any major rubbing or accelerated suspension wear?
Thanks,
Patrick
Old Jan 18, 2016 | 04:44 PM
Ham Bone's Avatar
Ham Bone
What the backspacing?
Old Jan 18, 2016 | 06:53 PM
schmidtp's Avatar
schmidtp
I am waiting on a reply but I have attached a picture of them if that helps.
Attached Thumbnails Wheel and Tire advise - 16x11 on stock suspension-centerline-wheels.jpg
Old Jan 19, 2016 | 10:32 AM
Think they are gonna be too wide...... you will most certainly rub in various places.
Old Jan 20, 2016 | 09:02 AM
schmidtp's Avatar
schmidtp
4" backspace with a 38.1mm negative offset. I am not worried about slight rubbing at full turn and other than over snow the truck won't see any extreme flex.
Old Jan 20, 2016 | 10:29 AM
Worth a shot...... Keep in mind, being 11 inches wide, you are going to want tires that are a bit wider than your rims.
Old Jan 20, 2016 | 10:37 AM
schmidtp's Avatar
schmidtp
I'll probably pick them up then since they are such a good price since I'll have to wait to save up for tires.
Any advise on tire size so I can start looking?
Old Jan 20, 2016 | 10:41 AM
33x12.5s would work. Don't really want to be narrower than 11.
Old Jan 20, 2016 | 12:57 PM
schmidtp's Avatar
schmidtp
Would a 285x75 be too close? Works out to be 33x11.22
Old Jan 20, 2016 | 01:33 PM
That would be ok. I would like wider.... helps protect the rim when off-roading. If you don't go off-road much, not as much of an issue.
