cold weather tramsnission blues
Old Jan 19, 2016 | 02:02 PM
horace's Avatar
horace
Default cold weather tramsnission blues
Sunday it was -32, Sunday before -27, my trans didn't shift going to church 15 mi. sat for 3 hr then shazam it shifts. I've had this w/ my 97@180,000, my 97 w/237,000 & 01 w/ 100,000, What's up wrench guys works perfectly otherwise? Thanks
Love my 2nd gen
Old Jan 19, 2016 | 05:38 PM
Apparently, it just doesn't like the cold. After sitting, and heat-soaking for a bit, things start working again. I am not entirely sure that there IS a fix for that.... you could try the borg-warner heavy duty solenoid/sensor set, but, no guarantee that will solve it.
Old Jan 19, 2016 | 06:18 PM
dbbd1's Avatar
dbbd1
El Cheapo dipstick heater normally used for the engine oil?
Old Jan 19, 2016 | 07:03 PM
UnregisteredUser's Avatar
UnregisteredUser
That's just the nature of the beast. When it's good and cold out and your truck's been sitting in it, shift into Neutral before starting the engine and leave it to idle until the temp gauge is about halfway from the bottom pin to the first bar of the normal range. That'll warm the ATF enough that it shouldn't cause any problems.
Myself, I avoid that problem by letting the truck sleep in the house at night.
Old Jan 19, 2016 | 08:07 PM
Does it sleep on the floor at the foot of your bed?
I think my dog would be pissed..... SHE gets to sleep on the bed.......
Old Jan 19, 2016 | 09:08 PM
UnregisteredUser
Nah. It sleeps under the sofa where the dog can't get at it to chew on it.
Old Jan 19, 2016 | 10:50 PM
That makes perfect sense. Smart truck.
Old Jan 20, 2016 | 01:39 PM
lance49726's Avatar
lance49726
http://dodgeram.info/tsb/1997/21-06-97.htm
Old Jan 22, 2016 | 12:36 PM
horace's Avatar
horace
Thank you @ least this winter it warms up a bit before it gets cold, 2 yrs ago it was COLD all winter
