hey im piggy from Indiana .. have issues with my 97 ram
Old Jan 22, 2016 | 04:22 PM
luvmy97ram's Avatar
luvmy97ram
Question hey im piggy from Indiana .. have issues with my 97 ram
i have read alot of different discussions but none have exactly described my issue ... i have a 97 ram pickup and my truck has been running fine and yesterday out of nowhere it seemed like my rear brakes were sticking after stopping and as i came to a stop my rpm dropped almost to 0 then i started to drive again just fine , as i came to the next stop rpm's dropped down again and then stalled out ( headlights and stereo stayed on) as the rpms dropped my heater and lights dimmed slightly but the only light on my dash that came on was the oil light ( checked and has plenty of oil ) so i put it in neutral and it restarted and ran fine till the next stop and stalled again and from that point i had to restart and baby it all the way home ... it has a half tank of gas and plenty of oil ... gave no previous warnings and not giving a code? .. seen a lot of post explaining how ppl have spent hundreds of dollars only to still have the problem.. i am no mechanic and dont have the tools or physical ability to chase ghost under my hood .. trying to get the best info before i go broke:/
Old Jan 22, 2016 | 05:03 PM
luvmy97ram's Avatar
luvmy97ram
the majority of post ive seen with similar issues have been fixed with either EGR valve or o2 sensor or battery , but still not finding a fix that im confident in so ill try to baby it over to advanced auto to check battery and alternator (just in case) to start with . open for suggestions
Old Jan 22, 2016 | 06:29 PM
44dakota's Avatar
44dakota
Hi miss piggy, if your truck starts right back up after dying at a stop light, then runs fine until it idles again, you need to replace your idle air control solenoid ...
Old Jan 22, 2016 | 07:42 PM
Or at least clean it out, and see if that doesn't improve its attitude.
97 doesn't have EGR.
Old Jan 23, 2016 | 02:14 PM
luvmy97ram's Avatar
luvmy97ram
thanx for the info ill give that a try .. still gotta test battery and alt cuz they havent been done in a while but makes sense ..thanx......... mr piggy, aka the bigpig, aka piglet
Old Jan 23, 2016 | 04:24 PM
zildjian3707's Avatar
zildjian3707
ya seems like an iac problem to me as well.
