Truck won't start
Old Jan 24, 2016 | 11:01 PM
Jonseyboy's Avatar
Jonseyboy
Default Truck won't start
Hey guys, I have a 99 cummins and it won'the start. It started and ran fine this morning but when I went to go to work it wouldn't crank or do anything. I have battery and everything electronic works fine. I just put a new starter in a month ago along with a FASS lift pump. There is two blown 30 amp fuses, but idk if that would keep it from starting. And the air bag light is now on the dash. Any suggestions? And it doesn't crank or anything also
Old Jan 25, 2016 | 07:40 AM
Start with replacing the blown fuses.....
Old Jan 25, 2016 | 08:32 AM
Jonseyboy's Avatar
Jonseyboy
Yeah it wasn't the fuses
Old Jan 25, 2016 | 09:00 AM
What is your battery voltage? How are the connections?
Old Jan 25, 2016 | 10:11 AM
Does anything at all happen when you turn the key to start?
have you tried swapping the starter relay with another one?
Old Mar 8, 2016 | 07:09 PM
carlrw's Avatar
carlrw
please delete this post
Old Mar 8, 2016 | 07:13 PM
stewie01's Avatar
stewie01
Originally Posted by carlrw
Any recommendations on what to test I have no transmission experience so any help is appreciated
What seems to be the problem officer?
Old Mar 8, 2016 | 07:16 PM
carlrw's Avatar
carlrw
https://dodgeforum.com/forum/1st-gen...t-working.html
I was trying to reply on another thread. Not sure how it popped up here.
Old Mar 8, 2016 | 07:39 PM
Mechanical_Tree's Avatar
Mechanical_Tree
Check your positive cable off the battery that goes to the solenoid. If it's loose it won't turn over just click once and youl still have lights.
The nut could had vibrated loose
