Wont start
Old Jan 25, 2016 | 04:01 PM
Tyrell Allred's Avatar
Tyrell Allred
Default Wont start
I have a 2000 dodge ram2500 wont start if the data link wire is connected on vp44 connector on pin 2 has active code 364 have checked pin 2 fuel pump connector to pin13 has .1 ohms pin 1 fuel pump to 23 ecm is .1 ohm is open to all other pins if you remove either wire off pin 1or 2 engine will run as soon as you touch wire engine dies . have tried new ecm does same thing any ideas??
Old Jan 25, 2016 | 11:24 PM
May wanna post this in the diesel section as well..... Not too many diesel guys around here any more. Used to have a couple, but, haven't seen 'em for a while.
Welcome to DF!
