leaking proportioning valve
Old Nov 22, 2021 | 07:44 AM
j404ski's Avatar
j404ski
I have the four wheel abs.
Old Nov 22, 2021 | 07:05 PM
Find yourself a stretch of empty road, run the truck up to about 30 MPH, and STAND on the brakes. The idea is to get the abs to engage. Do that a couple times, then go home and bleed your brakes again.
Old Nov 23, 2021 | 07:29 AM
j404ski's Avatar
j404ski
I'd like to try to get my hands on the scanner an electronically exercise it. My Dodge 3500 is on a motorhome Class B and I've got two rear tires off in order to access the bleeder valves. Any other tricks to use to energize the ABS system without driving down a gravel road?
Old Nov 23, 2021 | 09:49 AM
None I know of without a scan tool that can do it.
Old Mar 2, 2022 | 11:45 PM
Jjh1's Avatar
Jjh1
Default I have this problem too
Originally Posted by musteno802
Yes. It's leaking right out the bottom. There's a port or something, threads into the valve body. Has a hole through the center of it. Faces down.
  • Will I have to change the valve or is there a cheaper fix. Can that fitting/port or whatever be replaced or reseated?
Old Mar 3, 2022 | 12:00 AM
AtomicDog's Avatar
AtomicDog
Lightbulb
Do you happen to have a photo of the valve that you can share in the thread?
Old Mar 3, 2022 | 03:08 AM
Jjh1's Avatar
Jjh1
this one is listed on eBay for $125. I circled the part that is leaking which as in the photo is on the bottom.
Old Mar 3, 2022 | 01:26 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I believe that is a threaded bleeder. If it is try tightening it
Old Mar 3, 2022 | 02:28 PM
AtomicDog's Avatar
AtomicDog
That's a hard area to see clearly. Is there rubber and a pin in the center of that bolt at the bottom?
Old Mar 6, 2022 | 05:31 PM
Jjh1's Avatar
Jjh1
Default There is a rubber cap and then a bolt.
Originally Posted by AtomicDog;[url=tel:3538828
3538828]That's a hard area to see clearly. Is there rubber and a pin in the center of that bolt at the bottom?
I took the bolt off and the spring came out. I tried to take a picture of the inside and post it but it's so hard to get anything in there. This is the picture I have of it it's not very good. I also took a picture of the fitting/boat.
