leaking proportioning valve
Old Mar 8, 2022 | 11:21 AM
  #31
Jjh1's Avatar
Jjh1
Originally Posted by HeyYou;[url=tel:3539169
3539169[/url]]If the prop valve is leaking, you need a new one.
If the prop valve is triggering the brake lite, then yeah, it will annoy the ABS as well.
In all reality, I think the ONLY time the brake lite will be on, without the ABS light also being on, is when you are parked with the E-brake set.
Thank you so much for attending to this question and the forum in general. It helps a ton. I downloaded the service manual. All 2889 pages of it. Looking forward to the light reading. I will try to find a junkyard proportioning valve. They are no longer available in parts places that I can find. I will post a picture of the inside of the bottom of the valve if anyone expresses interest before in have it installed. Thanks.
