5 speed swap question
Old Feb 2, 2016 | 03:17 PM
shorty24v's Avatar
shorty24v
Default 5 speed swap question
Picked up a parts truck the other day it's a 1500 V6 5 speed
I also might be picking up a 2500 360 V8 auto truck.
I could use a backup truck to tow with so I was wondering could I swap the 5 speed from the 1500 into the 2500?
to simply here's what the two trucks specs are
1994 1500 reg cab long bed 2wd V6 5 speed (HD manual trans according to build sheet)
1994 2500 reg cab long bed 2wd auto 46rh
Old Feb 2, 2016 | 04:17 PM
Ham Bone's Avatar
Ham Bone
As long as both are 2wd. Take the manual and bolt it to the 2500. It should be a nv3500 which isn't really heavy duty per say. Will need a new 5.9 flywheel.
Old Feb 2, 2016 | 05:38 PM
Is the six the same bellhousing bolt pattern? (Is the 3.9 just a 5.9 minus two cylinders?)
Old Feb 3, 2016 | 09:30 AM
dapepper9's Avatar
dapepper9
Should be I've seen Dakota guys do the swap before. I believe the v6 version of the nv3500 is even lighter duty. IMO you'd be better off with maintaining your auto with a check valve delete, bigger cooler, and a shift kit.
Old Feb 3, 2016 | 09:58 AM
Ham Bone's Avatar
Ham Bone
Do the manual The nv3500 is rated to 300 hp and I beilive that is a conservative statement. It wont take the torque of a cummins for sure, but its a pretty stout trans and has good gear ratios for a daily driver.
Old Feb 3, 2016 | 10:07 AM
shorty24v's Avatar
shorty24v
Ok, I was just curious. I part the trucks out so I get them fairly cheap and sell enough off them so I get the parts I need for free. I'll end up making money off the 2500 and keep it to drive.
