Tranny fluid question
Old Feb 5, 2016 | 11:11 AM
wyrmrider's Avatar
wyrmrider
Exactly Correct Moparite
same as Ford FX type F only good now for some FORD power steering like Panthers (Crown Vic- Town Car)
THE ATF+4 is a better lube for the thrust washers in the OD but the big issue is tearing up converter clutches with non ATF4+ fluids
First they chatter then the lining comes off and plugs your cooler and lube then the OD goes really bad really fast
I was a Chrysler service manager back in the early 70's and still tight with a few
what I said above is GOSPEL.
Best thing to do is upgrade the 5/16 or 3/8 lines to diesel size 1/2 with big fittings
If trans is apart retap for larger and drill the case- tailshaft
the big tranny cooler with 1/2 in and out
especially with high stall converter or towing
Old Feb 5, 2016 | 12:46 PM
KevinAllen's Avatar
KevinAllen
Originally Posted by Billkerr74
Could u tell me the best brand to use?
A good name brand synthetic
Old Feb 5, 2016 | 01:41 PM
ramhuskyhauler's Avatar
ramhuskyhauler
Anyone have a source for 5 gallon pails for Dodge modern E transmissions?
I saw on Amazon a 5 gallon pail of Cam 2 synthetic for around $100, anyone ever ran this?
Old Feb 6, 2016 | 02:56 PM
wyrmrider's Avatar
wyrmrider
AS said above
If it's atf-4+ just buy the cheapest you can find it has to be synthetic with the proper additives
watch for weasel words like "replaces" or "compatible with"
Old Feb 11, 2016 | 05:35 PM
Billkerr74's Avatar
Billkerr74
Originally Posted by jkeaton
Who told you that? Really good stuff for what? At any rate, stick with ATF+4.
Thanks alot for the advise! Could u tell me also what woul b a good temp thermostat to put in my dodge?
Old Feb 11, 2016 | 06:07 PM
Nothing wrong with OEM.
Old Feb 11, 2016 | 11:30 PM
Billkerr74's Avatar
Billkerr74
K thanks I saw 2 diff temp thermostats when i was lookin them up
Old Feb 12, 2016 | 09:35 AM
Stock is 195, if your truck is basically stock, stick with the stock temp.
Old Feb 13, 2016 | 09:20 PM
bigaaron's Avatar
bigaaron
i use valvoline atf+4 only. If your in there do a band adjustment. Dont forget the throttle cable adjustment. Search my user for post and you will find it.
I changed my thermostat in my stock 360 to the cooler temp range and i used more fuel because the engine ran cooler, but tried to maintain efficiency.
