Questions about a 408..
Old Feb 27, 2016 | 09:18 AM
Moparite's Avatar
Moparite
I noticed the one you chose has a cast crank, If it where mine i would get one with a forged crank. The rest of the parts list is good. My $.02
Old Feb 27, 2016 | 10:36 AM
I suspect the kegger manifold is going to have a hard time feeding a 408.....
Old Feb 27, 2016 | 10:53 AM
Nate_rs's Avatar
Nate_rs
Originally Posted by kraven
Short block should come with the timing set and cam. Ask for it if you don't have a list of parts it comes with already.
Thanks I went ahead and asked for one
Old Feb 27, 2016 | 10:54 AM
Nate_rs's Avatar
Nate_rs
Thanks I'll ask the guy about that
Old Feb 27, 2016 | 10:57 AM
Nate_rs's Avatar
Nate_rs
Yeah I thought about that. I'm really trying to keep the cost down, but I may have to spring for that hughes intake manifold. We'll see
Old Feb 27, 2016 | 11:08 AM
I think your goals are mutually exclusive. Building a 408 is NOT an inexpensive endeavor. Granted, you could probably live with the kegger for a time, and then spring for the hughes, or M1 at a later date..... But, you are going to need custom tuning as well, and I highly suspect that swapping intakes would throw the tune way out of whack, and require retuning.... at an additional cost as well. I think you would probably end up at a lower cost, by just picking up either manifold right from the start, and tuning that combo.
Old Feb 27, 2016 | 02:56 PM
Nate_rs's Avatar
Nate_rs
Yeah I know its kinda funny that I'm "trying to keep the cost down" on a 408 lol
But you're right, probably smarter to go with the new intake, I'll go ahead and lump that into the cost.
Old Feb 29, 2016 | 01:56 PM
Nate_rs's Avatar
Nate_rs
There is no camshaft or timing chain on the short block but it does come with the cam bearings installed
Old Mar 3, 2016 | 12:40 AM
getdown78's Avatar
getdown78
What is the total cost of doing a 408 and swapping it yourself ? Pretty much cost of engine and extra stuff ?
Old Mar 3, 2016 | 08:44 AM
Depends on what you start with, and how crazy you get. You can figure right around 5 grand for a 'typical' build. But, then you need to consider everything behind the engine. The stock 46RE isn't going to last long behind a 408..... I wouldn't even consider putting one in front of an NV3500....
