Does not beep when locked but did before
Old Feb 16, 2016 | 05:27 PM
sunshine7323's Avatar
sunshine7323
Default Does not beep when locked but did before
Hello everyone, I was hoping I could find some advice. I own a 2001 Dodge Ram 2500 extended cab long bed 4x4 with the 24 valve Cummins. I noticed just this afternoon that the truck no longer beeps when locked with the key fob. The horn works from the steering wheel and the doors lock with no issue. I also understand that this is not a serious issue so please don't bother commenting if you're going to poke fun. thank you in advance.
Old Feb 16, 2016 | 06:18 PM
Stock, or aftermarket entry system?
Old Feb 16, 2016 | 07:24 PM
sunshine7323
bone stock
Old Feb 17, 2016 | 09:47 AM
Hhhmmm..... wonder if that was something that could be configured in some way..... My truck doesn't do that particular trick, at all.... so, I have no experience with it. Do you have an owners manual by chance?
Old Feb 17, 2016 | 09:58 AM
jsmith1969's Avatar
jsmith1969
Mine quit doing it too sometime last year, I searched the various forums and never found anything so please update if you find a fix.
Old Feb 17, 2016 | 05:09 PM
sunshine7323
Default Update: Fixed
Ok so you guys will get a kick out of this. So using the previous advice from "heyyou" I searched around in the manual for programming. It turns out I in programmed it with my knee without even knowing it. I'll tell you the procedure to put it back on for anyone interested. And again this is straight out of the Chrysler Dodge owners manual. 1. Turn your ignition switch to the ON position without starting it. 2. Allow all lights and dings to stop. 3. On your fob press and hold the UNLOCK button for 4 seconds. 4. While still holding the unlock button press the LOCK button. 5. Release both buttons and one audible ding from the dash will be heard. This means that your horn chirp is programmed. Very simple but obviously overlooked by yours truly. Hope this helps and thank you both for answering so quickly
Old Feb 18, 2016 | 09:57 AM
Coolness. Thanks for posting the solution.
Old Feb 18, 2016 | 10:11 AM
jsmith1969's Avatar
jsmith1969
Awesome! I'll try this soon as I get home from work.
Old Feb 18, 2016 | 12:00 PM
sunshine7323
let me know how it works
Old Feb 18, 2016 | 12:08 PM
Owners manuals are the most underrated/overlooked tool ever.
