?'s About Timing Chain
Old Feb 27, 2016 | 09:45 PM
xjarhead69's Avatar
xjarhead69
Originally Posted by Snowfan
100% TRUE. I manufactured plates until it was pointed out to me that the bolt length is too long to achieve proper clamping force. The 'dissimilar metals' theory is bunk. All you need is shorter bolts and clean metal surfaces. Apply a thin layer of black rtv to both sides of entire gasket.
Save your money and help stop the plenum propaganda.
What length bolts should be used?
Thanks
Dave
Old Feb 28, 2016 | 09:42 AM
Just an 1/8th inch shorter will be fine.
Old Feb 28, 2016 | 11:10 AM
xjarhead69's Avatar
xjarhead69
Ok thanks
Dave
Old Feb 28, 2016 | 01:00 PM
Snowfan's Avatar
Snowfan
Thanks
Dave
1/4-20 x 3/4
If you have a vise and grinder you can grind off the unthreaded nipple on the tips of the bolts and get to the right length.
Old Mar 5, 2016 | 01:08 PM
xjarhead69's Avatar
xjarhead69
Thanks for the idea and the pics.
Dave
Old Mar 5, 2016 | 01:58 PM
stands2p's Avatar
stands2p
many years ago i put the shorter bolt theory to the test and it did not work.3/4 bolt is to long and will bottom out as the oem is only a 1/16 longer but not threaded all the way as a standard bolt would be.i used 1/2 bolt and it torqued down perfect but again it did not work cause the root cause of the plenum is the two diff metals expanding and contracting at a diff rate.in fact aluminum expands/contracts twice that or 2x the rate as iron.oem metal plate is sawing at the plenum gasket pushing said gasket out very similar to a head gasket being sqeezed out.thats the reason mopar and fel-pro designed a metal/metal core gasket.for the price of a aluminum plate its worth the peace of mind that this proven repair will not fail.
Old Mar 5, 2016 | 02:06 PM
Wrong. The two metals theory has been disproved multiple times here. If you couldn't get a steel pan to seal with shorter bolts, and a good gasket, then it would be the workmanship I would question. I went and did the math on the 'dissimilar metals' theory, and the movement was measured in ten thousandths of an inch. Not enough to make any difference whatsoever.
Old Mar 5, 2016 | 02:36 PM
stands2p's Avatar
stands2p
your math and advise has no experience actually working on 2nd gens only copy paste from what you have read.i actually wrench on my ram and have done alot of modifying/testing first hand so my math and advise workmanship come from experience working on my ram not from reading it.
Old Mar 5, 2016 | 02:43 PM
AHHAHAHAhahahahaaaaaa. I am not even going to bother with any more of a response than that.
Old Mar 5, 2016 | 02:57 PM
stands2p's Avatar
stands2p
i apologize if the truth hurts so dont throw rocks and not expect them to be thrown back with experience
