Possible to disable accessory position?
A non-profit for whom I volunteer has a '98 Ram 1500, 4x4, 360. As it is now you can turn the key all the way back to accy (and it's disturbingly easy to do, esp for a vehicle that's driven by multiple people in a day) and then remove the key. Now if you do this it DOES ding at you but many newbies don't know what this means, and it's difficult to train them on the "gotchas" of our multiple trucks. However sometimes we don't remove keys from the ignition at all, and thus it's still just too easy to turn it back to accy thinking you're in "OFF" and walk away.
Is there any way to simply disable the accy position altogether? It's not needed and never used.
There may be a way to disable it or just get a new ignition switch. But I imagine a non-profit doesn't want to spend that kind of money on a minor issue so personally I would put a reminder on the steering wheel or dash saying to check the position of the key before removing it or exiting the vehicle if it is dining at you.
You could hook up a radio shack buzzer to it. +12 to it from the radio (acc switched plus), ground to the buzzer from the door switch when it gets opened. If the key is in the acc position and the door is opened, the door switch will activate the buzzer.
Sometimes we don't remove the key at all however and in that situation an operator could turn it all the way back to accy and simply exit the vehicle. A new lock cylinder wouldn't help here. A buzzer wouldn't help here either, too many people and it's just not realistic to expect them to know (what a buzzer means).
The bottom line is we really need no possibility of an accessory postion.
Does anyone have any tech on if there's a wire unique to accy I could simply snip, OR a way to physically modify the cylinder?
