#1 PICTURES or none of this ever happened!
#2 Did you install them yet?
#3 Did it fix the problem?
#1. I can take a few pics later today sometime. say of the shredded front band if I find it (scrap metal bin), the carton and old GOV sensor/tranducer pair, and the shelled Main case, and under the truck of the Shiny New Black AT Pan I guess.
#2. Yes
#3. Abso-friggin-lutely
She ain't No street Beast, or lifted Toy, But I am extremely happy this nightmare is over and she is back up to being the reliable, loudmouth, I've known her to Be, actually better than before.
I suspect the Gov had been going for some time because Now You can tell when and where She cut to the next gear + You can make a distinction of whether or not the OD is On or OFF just by the differences in shift RPM unlike before the band blew apart.
I see rookie next to you name which gives you NO power to be a D!ck, and until it says MODERATOR or ADMIN next to your name; Don't say crap like that to ANYONE on the DodgeForum especially not ME.
Blown Main case and outer Sprag/Reverse support
Commonly broken OEM Front Band Servo Piston & spring retaining collar that breaks off the Pin
Ease up there, Double Oh, the 'pics, or it didn't happen' thing is just a tease. Don't take it too personally, we are all friends here, so, handing out a ration of sht isn't all that unusual.
When you grenade a case, you don't fool around, do ya? Do you build transmission for a living? Or, just as a hobby?
My bad.
AS for the AT......Necessity!
I refuse to pay "Professionals" for shop cost on anything I can or could do myself.
$1800 For a NEW/Reman + $15-20phr labor? NOOOOO not happening!
All Done I have Maybe $600-$800 into this AT crap including replacing the Bombed one.
On that note to blow the case, I honestly suspect the snap ring failed that keeps the reverse drum and parts snugged to the sprag and the case back Failed.
If I have to monkey with an AT again it will be too soon and I just might get suicidal over it!!
My bad.
LOLOL. Yep. I hear ya on that one, and wholeheartedly concur.
It's all black magic as far as I am concerned, spin one end, and it comes out there other faster, slower, or the other frigging way...... what happens in between? Black Magic. Yep. Capital letters.
Sprag failures are nothing new, I had one let go at stop light in a 727. It broke the case to the point it protruded out the top. No pics as this was in the 80's. The new case i had a bolt in sprag put in to prevent the same failure.
Not sure, I looked for them and they seem to be available for the A518 so i assume it would fit a 46RE.
There probably is, I never thought about it or saw one recommended, or suggested elsewhere in my research.
BTW the A518 IS a 46RE, but only by as much as the 5.9 Magnum is still true to the Original 1971 360-E58 Engine.
Same thing with a tweak and a quick relabeling.
Just a short list of currently pointless, information that someone my find interesting or useful later...............
