Obd 1 tuner?
Old 04-03-2016 | 12:25 PM
jrox44's Avatar
jrox44
http://m.ebay.com/itm/94-95-Dodge-Ram-1500-2500-5-9-A-T-Engine-Computer-ECM-PCM-56028276-/262359444833?_trkparms=aid%253D222007%2526algo%253 DSIC.MBE%2526ao%253D1%2526asc%253D20150519202348%2 526meid%253Da1e61baaa0814b9099cb64940759f6c4%2526p id%253D100408%2526rk%253D1%2526rkt%253D1%2526sd%25 3D291723252741&_trksid=p2056116.c100408.m2460
Is this the right one? It doesn't say mopar performance pcm thou. Mopar discontinued the product I just called summit. If this is the right one and a performance pcm . I'm buying it
Also found remanufacted. But idk if their performance pcms or just stock it doesn't say
http://m.ebay.com/itm/291723252741
  #22
Old 04-03-2016 | 12:49 PM
cruzer55's Avatar
cruzer55
Yes they will be stamped re-man,as the case has been' cracked;and the part number as stated P5249546,OBD 1 for 94&95.
  #23
Old 04-05-2016 | 02:29 PM
jrox44's Avatar
jrox44
I messaged the guy and he said it was stock. But it looks just like the performance one with the fins on the front. And I called summit and acouple others and mopar discontinued the performance pcm for the 360ci motors. The guys on the phone said I gotta find someone who still has some on the shelf cause they quit making them. All the people on ebay say their stock pcms. But my stock one doesn't have the fins on the front. So idk if they don't know or what
  #24
Old 04-05-2016 | 03:30 PM
Moparite's Avatar
Moparite
e if you can find an old mopar performance catalog from the era when they actually made them. You need to go by the part #,This is key! Don't take someones word that it is a MP unit unless it has the correct part #. I have several of the catalogs but not sure what the dates are on them. These PCM's where only produced for a few years after they came out this is why they are hard to come by. They where made for a variety of vehicles over the years. I have one on my 1986 Daytona turbo Z and it took a while to find one(pre internet). Not sure if the part #'s are listed on the internet anywhere.
  #25
Old 04-05-2016 | 07:56 PM
The War Wagon's Avatar
The War Wagon
Cool
Ta da.
http://www.campbellenterprises.com/d...ccessories.php
Scroll down - almost to the bottom. No matter your OBD-I engine, they have your performance ECU.
  #26
Old 04-10-2020 | 04:13 AM
Brandon Wilde's Avatar
Brandon Wilde
Default Only real obstacle there is, on the OBDII fellers, the trans is also controlled by th
To convert, you would need to OBDII PCM, the underhood wiring harness, and also the under dash wiring harness.... ... Unless you have a manual trans?
So my big question is what do you do about that tranny issue? I put a 2001 46re in my 96 that had the 46 re. My performance pcm automatically kick trans temp light and over drive off. So I slapped the pcm from the 01 on my 96 ran great but the gen light stayed on (tested many times and was charging 14 at battery, it gave up and I want my performance pcm what do I have to do to get it to work?
  #27
Old 04-10-2020 | 08:27 AM
What year is your performance PCM compatible with?
I think the biggest problem is, the electronics in the trans changed in 00. The sensors use a different range of values. So, swap out the 01 sensors, for sensors for the 96, and the correct retainer, and the trans should work just fine. Need to change O/D and TCC solenoid as well, as the internal connector for them is different as well.
Quick Reply: Obd 1 tuner?
