Hello. Need help guys.
Old Mar 29, 2016 | 06:22 PM
LithSOF's Avatar
LithSOF
Unhappy Hello. Need help guys.
Hello. Im from Lithuania. I bought "new" DODGE RAM 1500 MAGNUM 5.2 V8 RWD truck. And got problem... Problem is that when i shift reverse it starts to choke and stall. Exactly at that time check engine light appears on dashboard. So,guys and maybe girls... Can i get answer or some kind of clue??? Wtf happens with my RAM? P.S. Sorry for grammar... Just as i said- Im from Lithuania... ^_^ Thanks a lot.
Old Mar 29, 2016 | 06:25 PM
What year is your truck?
Old Mar 29, 2016 | 06:33 PM
LithSOF's Avatar
LithSOF
Originally Posted by heyyou
what year is your truck?
2001 5.2 rwd v8 1500 MAGNUM
Old Mar 29, 2016 | 06:34 PM
Does it do the same when you put it in drive? Any better when the engine is warm??
Old Mar 29, 2016 | 06:37 PM
LithSOF's Avatar
LithSOF
1,2,3 Gears looks like ok,but when it start to warm reverse cause that issue... Choke,check engine on dashboard,and at last hes off.
Old Mar 29, 2016 | 06:38 PM
Read the codes, and see what it has to say for itself. I don't know if the key trick will work for you..... but, cycle the ignition on/off/on/off/on, and see if it will display codes on the odometer.
Old Mar 29, 2016 | 06:47 PM
LithSOF's Avatar
LithSOF
Its some kind of self diagnosis?
Old Mar 29, 2016 | 06:48 PM
Supposedly, I don't remember if the 01's still do that though.
Old Mar 30, 2016 | 09:16 PM
cruzer55's Avatar
cruzer55
Ask around for a shop with OBD ll code reader,it;s easier than counting flash,and they might be able to make repairs.Just a thought...
