1994 Ram 1500 Dome Light not working
Old May 12, 2016 | 08:33 PM
  #21
primem's Avatar
primem
built with overhead console or without? not that it matters anyway both builds grd though the headlamp switch...why not go there first and jumper grd? You have power, just need grd right?
Old May 13, 2016 | 01:13 PM
  #22
Randy1951's Avatar
Randy1951
I have the plastic part from under the steering column removed and am looking for large connector type things just to the right of the fuse block. Would be helpful if I had a picture of it, but cannot find one just looking for parts online. From schematics it appears to have 10 connectors, three of which are the door jambs and dome lamp and I would think a fourth would be attached to the headlamp switch. Going back outside now to take a closer look to see if I can see where the wire that runs under the left door jamb comes out and connects up under there.
Old May 13, 2016 | 01:28 PM
  #23
Randy1951's Avatar
Randy1951
Good news is I think I found Joint Connector A. Bad news is, I can't figure out how to detach it from what appears to be a larger joint connector and the wires I need to test are on the back side of it.
Old May 13, 2016 | 08:54 PM
  #24
Friar Tuck's Avatar
Friar Tuck
Lightbulb Connector Location
Originally Posted by dbbd1
IIRC, it is directly on the back side of the interior fuse block. I can check later though.
According to DBBD1 in an earlier post, it's attached to the back of the fuse block.
Old May 13, 2016 | 10:30 PM
  #25
Friar Tuck's Avatar
Friar Tuck
Think I broke the thread.
Old May 13, 2016 | 10:57 PM
  #26
Holy crap.
If you can, edit the post, and nuke that URL. I can't even get to the moderator controls to nuke it....
Old May 13, 2016 | 10:59 PM
  #27
Holy crap.
nevermind, I went about it from a different angle.
Old May 13, 2016 | 11:11 PM
  #28
Friar Tuck's Avatar
Friar Tuck
Thanks, HeyYou. That was a wiring chart from a 98 manual that I downloaded. After I posted it, I couldn't access it at all, and everything on page 3 of the thread continued off the right side of the screen. I was able to send posts from page 1 and 2, however.
glad you saw it and could fix it. I PM'd Randy to alert him.
Old May 14, 2016 | 01:21 AM
  #29
UnregisteredUser's Avatar
UnregisteredUser
Good job, mang!
Not that it was your doing -- vBulletin is junk. I could see the post just fine, and it was an improperly Base64 encoded image that must have got stored that way because repeated reloads kept delivering the same busted encoding. Let us not now consider the stunning brilliance of what must have happened to make a busted Base64 file be served in the first place...
Old May 14, 2016 | 01:31 AM
  #30
Friar Tuck's Avatar
Friar Tuck
You smooth-talker
