Still missing after plenum fixed
Old Apr 14, 2016 | 06:41 PM
  #31
What's it look like? Is it black and oily, or is it just ash deposits? How long has it been in there?
Old Apr 14, 2016 | 06:44 PM
  #32
galindojcuerotx's Avatar
galindojcuerotx
Nope not the sleeves around spark plugs either. Man I am aggravated
  #33
galindojcuerotx
Black and oily kinda wet
Old Apr 14, 2016 | 06:46 PM
  #34
Valve seals are REALLY bad then, and probably cracks around the valve seats. Unfortunately, all too common on these engines, especially with high mileage. At 260K miles, it is getting on toward time for a rebuild.....
Old Apr 14, 2016 | 07:08 PM
  #35
galindojcuerotx
Only #8 WS fouled all the rest look great
Old Apr 14, 2016 | 07:30 PM
  #36
galindojcuerotx
Got the low down from the previous owner, my bro in law, he said the bouncing started one day after he changed the plugs, and it wouldnt go over 55, It sat for 4 months then i bought it for 300 bucks, I looked around and noticed right off the bat that he crossed two wires, rectified that and it ran fine except for the bouncing that is from a random misfire, the only thing I haven't changed since then was the ignition coil or the pickup coil
Old Apr 14, 2016 | 07:36 PM
  #37
galindojcuerotx
I am seriously thinking it may be something electrical, sensor or connection. About ready to commit a murder suicide, shoot the truck then myself.
Old Apr 14, 2016 | 09:29 PM
  #38
adukart's Avatar
adukart
I would replace the PCV at this point as well, won't cure it but should help any vacuum operated/controlled systems. Put in a new coil. But a leak down with compression will really tell what kind of shape that motor is in. Also is there oil in the plenum again? This happened to me where I did the plenum and had oil in the intake immediately after, and it was the PCV. With that many miles if there was any pre-ignition from those wires being crossed it could have cracked something, was one of the crossed wires cylinder 8?
Old Apr 15, 2016 | 09:22 AM
  #39
galindojcuerotx
No #8 was not one, number 8 is toward the back of engine the two that had been crossed were in the middle not sure what cylinders without looking
Old Apr 16, 2016 | 12:17 AM
  #40
ReadRam's Avatar
ReadRam
Check compression...Probably find 8 is low.
