Still missing after plenum fixed
Old Apr 16, 2016 | 04:02 PM
  #41
galindojcuerotx's Avatar
galindojcuerotx
No oil inside intake, but new pcv valve is rattling, I also have the wild vents issue. Always have it sucks cause the ac blows snowballs. I had an issue with the blower motor once had to keep tapping on it, but one day the connection for the motor fell from under dash and I realized it was loose pushed it back together and has worked every since.
Old Apr 16, 2016 | 04:08 PM
  #42
PCV valve is supposed to rattle.
Wild vents can be fixed with a couple check valves. Articles in the faq section for that.
Old Apr 16, 2016 | 04:31 PM
  #43
galindojcuerotx
I put a check valve in the line still no help, with the wild vents.
Old Apr 16, 2016 | 04:36 PM
  #44
galindojcuerotx
Unfortunately the pick up coil wasn't the misfire problem either
Old Apr 16, 2016 | 05:58 PM
  #45
Of course not. The "pick-up coil" is only used by the PCM to determine which injector to fire. It has nothing to do with ignition.
Crank sensor is for ignition.
Old Apr 17, 2016 | 02:34 PM
  #46
adukart's Avatar
adukart
If you are still having a wild vents issue then you have a serious vacuum leak. Visually check everything.
